Folder tabs lost at next start
Posted: 07.04.2011, 18:06
by braveregan
several folder tabs are opened on version XE 0.532, when Freecommander XE is closed, folder tabs are not saved in ini file.
This issue is caused due to my own wrong configuration, XE 0.532 itself has no problem, this is not a bug. With the help from ralfso, I double check the options and now problem has been solved.
Re: Folder tabs lost at next start
Posted: 07.04.2011, 19:40
I experience no such bug [XE 532 ("Start with last used folders" is ticked) on win7x64].
Check to see if you have write access to the folder where "FreeCommander.ini" is located.
Posted: 09.04.2011, 00:12
by braveregan
joby_toss wrote:I experience no such bug [XE 532 ("Start with last used folders" is ticked) on win7x64].
I have access right, other options are saved in ini file quite well. just folder tabs opened are lost at next new start. my windows operation system is windows xp.
Posted: 09.04.2011, 06:37
by ralfso
Have you checked the options?
Especially the entry "Close all not locked tabs when program end" at Folder Tabs > Tab Management
Great, folder tabs issue is solved now
Posted: 09.04.2011, 22:17
by braveregan
ralfso wrote:Have you checked the options?
Problem solved after disable the option "Close all not locked tabs when program end".
Thanks for the help.
