Right-click on some filenames does nothing ?
Posted: 07.06.2011, 16:13
by James2000
Hi All,
I am currently using Free Commander version 2009.02b on Windows 7 (64 bit).
I have noticed that Right-clicking on some files does not display the pop-up menu? For example some EXE files and LNK (shortcut) files?
Please can you advise if this is a known issue, or is there a way to enable Right-clicking on these files?
Thanks your your time,
Regards,
James
Re: Right-click on some filenames does nothing ?
Posted: 07.06.2011, 16:44
by James2000
I think I have FIXED this problem by locating the "FreeCommander.ini" configuration file and adding the following two lines to the "[Form]" section :-
ShowContextMenu64Bit=0
AutoCloseTimeContextMenu64Bit=10
Thanks,
James
