[Solved] R545 - open Tab -> last used path should be active
Posted: 27.07.2011, 11:17
I refer to this posting:
viewtopic.php?f=2&t=3259&p=9620&hilit=Tabs#p9620
to this question:
to this question:
I get the answer that it is possible in XE but I can't find it.- Is there any setting that the last path is active when I activate the locked Tab?
