Solved:Weird! - zipped properties give up display properties
Posted: 10.08.2011, 00:33
I downloaded an application in a zip file. I entered the zip folder in FCXE and then clicked on the "properties" button which I have in my splitter bar. Of all the things in the world, it opened "Display Properties"! Now, I know better than to check properties of a file inside a zip folder, but I did it anyway. I am using Windows XP Pro SP3 and FCXE 548.
I realized how dumb a title I had give the original post so I decided to change it to something proper. Then I thought to test whether the issue was still valid - and it ISN'T! Either there was a fluke or Marek seems to have fixed it in the new betas. Thanks, Marek!
