553 - Drag&Drop Slow Confirmation with many files
Posted: 21.09.2011, 01:43
Win7 - 64bit
When a lot of files (>1,000) are selected to copy\move from one panel and dragged to the other it takes a very long time for the move/copy cursor and/or the popup dialog to appear. Almost seems to hang FC but if you wait long enough it will.
On the other hand, using the right click context menu copy/move with many files selected is pretty quick.
