550 Locked Folder Tabs and Tab Caption Issues
Posted: 09.10.2011, 17:13
I just recently downloaded and installed FC XE version 550. I am running it under WinXP SP3 with the latest updates.
My first impression is WOW! Great job! I like the UI and FC XE is very responsive, for example, file copy operations are extremely fast.
I have noticed the following behavior:
I have a folder tab which is locked at the root directory with navigation allowed (for example root C:\ tab caption: #C:System (C:)). I navigate within this tab a few directories down (for example C:\Windows\Prefetch). Then I right click on this tab and select "copy tab to other panel". The tab is copied and the tab caption shows the name #C:Prefetch but the address bar contains the root directory. The tab is also displaying the files contained in the root directory. Also the original tab caption now shows #C:Prefetch instead of the original #C:System (C:). I have to unlock the folder tab and lock it again to reset the tab caption.
If I have navigated within a folder tab locked with navigation allowed (for example root C:\ tab caption: #C:System (C:), after navigation for example to C:\Windows\Prefetch) and then open up the settings dialog and change a setting, then the tab caption shows #C:Prefetch. If I click on another tab and then click on #C:Prefetch, the address bar displays the root directory, which is the original locked directory for the tab, the tab caption in the tab remains incorrect (i.e. #C:Prefetch). I have to unlock the folder tab and lock it again to reset the tab caption.
