558 - Filter Both Lists Activates on Opposite Panel Only
Posted: 21.10.2011, 01:45
When two panels are open and a filter is set through the "Set filter" dialog with the "Use for both lists" option set, the filter is applied to the opposite panel only and not the active one.
