576 - NC-Mode - problems with selections and drags
Posted: 24.01.2012, 00:18
Release 576 fixed two problems associated with NC-Mode drag operations, but now selections occur unexpectedly in NC-Mode, and some drag operations do not work. (Win7/64)
DRAG PROBLEM
L-click drag to the other panel does not work (no copy/move icon during the drag, and the dragged item does not move). However, L-click drag to a folder in the same panel does work.
SELECTION PROBLEMS
(1) After adding a new file or folder, the new name will be selected.
(2) After renaming a file, the new filename is selected. (This does not occur if a folder is renamed.)
(3) Select X number of items, then move by drag and drop to a folder. The next X number of items in the origin will be selected.
(4) Select X number items, then copy by drag and drop to a folder. The original items remain selected.
EDIT: The items will be selected even in normal select mode (non NC-mode).
(5) After performing either (3) or (4), open the destination folder. The moved or copied items will be selected.
I think none of these selections would normally occur.
DRAG PROBLEM
SELECTION PROBLEMS
