578 Multirename Name from x to y
Posted: 17.02.2012, 07:05
The Multirename function Name from x to y does not create the Name from x to y as it says, but instead the Name from x with length y characters.
You should either
- change the name of the function or
- change the behaviour
so that the function does what it says.
You should either
