Multirename - failing to close dialog after rename
Posted: 18.02.2012, 10:07
In Multirename, when I first set the option "Close dialog after rename" I tested it and it worked.
Since then it has not worked, and I have to click on the Close button to close the dialog. I have checked each time that the option is still set in the Options menu.
Apart from that I've had no problem with the function, but then my particular use of it is very basic, so I am not noticing bugs that others may report.
Later note:
Just remembered - there is another, associated malfunction. When I have exited Multirename after its failure to close automatically after rename, I cannot then drag/drop the renamed file into a subdirectory as I normally can. What happens when I try is that I get the file rename dialog instead. That happened again just now, though once I'd changed focus to here (i.e. in my Firefox browser) and then went back to there, I could then drag/drop the file into the subdirectory.
Later note:
