579 Tab highlight does not follow active panel
Posted: 21.02.2012, 18:53
by Scott_Y
579 introduced a new feature under Folder Tabs > Tab Colors: "Use highlight color only for active panel." The highlight is the colored bar at the top edge of the tab (dark blue by default).
However, if this option is enabled, the highlight does not follow the active panel. Instead, it remains in the panel which was active when the option was applied -- whether it is currently active or not.
Personally, I don't think this feature is helpful so I probably won't use it. But I am just reporting what appears to be a bug. (Win 7/64)
Re: 579 Tab highlight does not follow active pane
Posted: 21.02.2012, 20:51
by ralfso
You're right, this feature doesn't work for me either.
Re: 579 Tab highlight does not follow active panel
Posted: 21.02.2012, 21:59
Hm, it works for me.
I need your ini file.
Posted: 22.02.2012, 17:01
by ralfso
Addition to this topic:
The highlight does not follow the active panel,
but when going with mouse pointer over the active tab without the highlight-bar,
the highlighting appears and is present even if the panel is changed again.
INI is sent by e-mail.
Posted: 22.02.2012, 18:05
by Scott_Y
INI file sent by email.
Posted: 23.02.2012, 20:46
Fixed for the next release.
Re: 579 Tab highlight does not follow active panel - FIXED
Posted: 15.03.2012, 01:21
by Scott_Y
Verified to be fixed in 581. Thanks, Marek.
