579 - Address vs. "go up" issue
Posted: 02.03.2012, 20:56
I've got several folders as "Favorite toolbars" and I found a bug.
If the address ends with "\" (e.g. "D:\Programs\FreeCommander\"), then "go up" doesn't work in that directory ([..] item, backspace key, button).
If the path is changed manually, the last "\" is removed automatically, so to reproduce you have to define a path with "\" at the end in Favorite toolbars.
I'm using NC mode and single click for files and folders, so enable these options if you can't reproduce it.
Re: 579 - Address vs. "go up" issue
Posted: 03.03.2012, 21:50
Fixed for the release 580.
