579 - I can't see the "C:\Windows\System32\spool" folder
Posted: 12.03.2012, 15:56
by tree
I can't see the "C:\Windows\System32\spool" folder in FreeCommander XE 579,
but I can see the folder in Windows Explorer.
My OS if Win 7-64
Re: 579 - I can't see the "C:\Windows\System32\spool" folder
Posted: 12.03.2012, 20:39
by ralfso
Posted: 12.03.2012, 20:50
by Scott_Y
This link says the user will be redirected to %windir%\SysWOW64. But the FCXE address bar says it is indeed C:\Windows\System32. From there I can go up and over to C:\Windows\SysWOW64, so it appears I can get to each folder as desired. Or is the C:\Windows\System32 address actually a spoof?
Whatever the case, my experience is the same as tree's. Win7/64.
Posted: 12.03.2012, 21:08
It works OK for me (I can see and browse "C:\Windows\System32\spool" folder in FreeCommander XE 579 on my win7x64sp1).
Posted: 13.03.2012, 08:45
by tree
