570 - hot tracking - rename bug
Posted: 13.03.2012, 15:01
by therealjd
I enabled hot tracking and single-click on folder. If i select a folder in the file browser and press F2 to rename it, it seems to select older selection instead of the current one..
If i disable hot tracking, the rename seems to work as expected..
Re: 570 - hot tracking - rename bug
Posted: 13.03.2012, 21:10
Have you defined "Hoover time for select item"?
Posted: 14.03.2012, 23:45
Can't confirm, please test with 581.
Posted: 19.03.2012, 14:48
by therealjd
these are my settings..
I think i know what's going on. Whatever was last selected for a FILE gets the rename command applied, even though i deselected it, and have a folder selected instead. It does not do the same for last selected folder, but if i went into the folder and then backed out of it, select another folder and press F2 to rename, it still picks the last folder i was in. I hope that's clear..
