581 - Multi rename "start with last used settings" broken
Posted: 20.03.2012, 21:38
"Start with last used settings" doesn't work suddenly. One old configuration is used every time.
Re: 581 - Multi rename "start with last used settings" broke
Posted: 24.03.2012, 14:24
Please check again in 582.
Posted: 24.03.2012, 15:59
Still broken.
Should I change something in the ini file to fix it? Where should I search?
Posted: 24.03.2012, 17:13
Try to remove the section "LastUsedSettings" from your .mren.ini file.
Posted: 24.03.2012, 18:20
Now there is [n] all the time there, still not working properly.
Posted: 24.03.2012, 23:24
I think, I have found the bug. Last used settings are not saved if you do not activate Profiles tab.
Posted: 24.03.2012, 23:40
Confirmed, you are right!
