582 - Minor - Path text color in address bar
Posted: 24.03.2012, 15:00
Path text color in address bar, in inactive panel on start is black (in settings it's white). On active panel it's OK, also if the tab is changed, it works good then.
- use white color for address bar inactive panel
- make left panel active! (it works good if right panel is active)
- save settings
- restart FC
= path text color in address bar on right panel is black
- save settings
- restart FC
