582 - file container content lost if panel swapped
Posted: 29.03.2012, 02:12
by inglorious
to reproduce:
1. create a new file container tab
2. drag & drop some files/folders into it
3. now swap panels (ctrl+u)
-> .fcc file content is gone
Re: 582 - file container content lost if panel swapped
Posted: 02.04.2012, 22:23
It works properly for me.
Posted: 02.04.2012, 22:51
by inglorious
Marek wrote:It works properly for me.
you probably saved the container file. to reproduce the issue, create a new file container, don't save it, drag & drop something into it, then swap.
Posted: 02.04.2012, 22:56
OK, you are right.
Posted: 07.04.2012, 03:00
by inglorious
bug only partly fixed in R584.
to reproduce:
1. create or open an empty file container
2. click to "add items to container from another file container"
3. select a well-stocked file container
4. files are added correctly to new container
-> now swap panels to lose file content of new created file container.
Posted: 11.04.2012, 22:50
Fixed for the release 585.
Posted: 20.08.2012, 21:34
by Scott_Y
This works properly for me in 598. Win7-64.
