Drive icons issue
Posted: 29.03.2012, 18:48
The same drive icon looks good in the file list (on right), but bad in the address bar (on right). The edges are white on bark background.
Are the same icons used? Where is the problem? All drive icons (incl. CD/DVD) look worse in the address bar.
Similar issue:
viewtopic.php?f=6&t=4122
Re: Drive icons issue
Posted: 25.05.2012, 16:12
by BGM
Hmmm... Dreamer, I know this post was from March - but I haven't noticed it myself. Is it still the case for you? My own addressbar is a pale yellow when active and is the "control" colour when inactive. If there were the extra pixels around my icons, I wouldn't even see them anyway - but I can see the problem for you with your dark colours.
Posted: 26.05.2012, 01:19
It is still actual, I know it looks unimportant, but it looks ugly and the small things are the reasons why the new users are considering if the program is worth trying...
Another similar issue is the toolbar dividers, but I'll start a new topic for that issue...
Posted: 28.05.2012, 16:15
Fixed for the release 594.
Posted: 28.05.2012, 17:29
by BGM
Marek, would be any value to you to have some screenshots of our FC setups? That is, if we showed you what our usual FC window looks like? Everybody has a different approach, you know.
Posted: 29.05.2012, 23:54
Thank you, Marek - and also BGM for opening the topic!
Posted: 30.05.2012, 00:16
by BGM
Glad to be of service!
Posted: 30.05.2012, 22:26
BGM wrote:Marek, would be any value to you to have some screenshots of our FC setups? That is, if we showed you what our usual FC window looks like? Everybody has a different approach, you know.
If you have a similar issue, start a new topic with the screenshots.
Posted: 30.05.2012, 23:09
by BGM
I don't have any issues.
Posted: 03.06.2012, 00:06
Thanks.
