Rel.582 - Tab problem
Posted: 04.04.2012, 17:59
Using Release 582, I've a problem with automatically closing not locked tabs. The option is checked within the settings, but everytime I close the program with an opened tab and start again, that tab will be open again and the folder too. Strangely enough, when the opened tab is the same as one of the locked tabs, it will close perfectly when I end/start the program again...
I saw that user "monaro" had the same problem on 10.09.2011, but there was no solution for it other than to scan the PC for a Trojan Virus? I did and my system seems to be clean.
I (still) use Windows XP - SP3.
