584 - Focus issue
Posted: 06.04.2012, 16:24
To reproduce use list view, go to folder with many subfolders (50+) (so that the number of rows in status bar is 1), enter the subfolder (so that the number of rows in status bar is 2), then go up ([..]). Focus is not lost, but the wrong column is displayed, so the focused item is not visible. Using the arrow keys helps.
Edit: I can't reproduce it with any subfolder, when testing use small FC window, 200+ subfolders and try to enter more subfolders.
...So now I can always reproduce it with the last subfolder - panel is empty this time, also test it with the other subfolders near the last one.
Win Vista 32 bit, SP2.
