586 - incorrect quick view alignment behavior
Posted: 13.04.2012, 01:17
by inglorious
1. select a file, press CTRL+Q
2. go to "Tools" Settings, Viewer and click "Apply"
-> quick view alignment toggles from bottom to right, although "Align in Panel" radio button indicates one single position.
under some circumstances this toggling occurs also if FC is closed with a quick view open.
http://www.2shared.com/file/lCLPfhaX/align.html
Re: 586 - incorrect quick view alignment behavior
Posted: 23.04.2012, 22:44
Fixed for the release 587.
