586 - crash: show drives as popup button
Posted: 13.04.2012, 15:01
by inglorious
go to settings, change "Show drives as button bar" to "show drives as popup button", click Apply.
-> Crash
Windows 7 x64 Service Pack 1 build 7601
Access violation at address 008F998A in module 'FreeCommander.exe'.
update: you don't need to change anything, simply RMB to change drive Settings, then click "Apply" to crash.
Re: 586 - crash: show drives as popup button
Posted: 13.04.2012, 22:12
I can't reproduce it, R586, Win Vista 32 bit.
Posted: 13.04.2012, 22:23
Can't confirm, either.
win7x64sp1; XE586
Posted: 14.04.2012, 00:24
by inglorious
issue 100% reproducible in win7x64, see video. make sure to delete your settings folder to have a clean 'installation'.
http://www.2shared.com/file/g0Eqnqjd/crash.html
Posted: 15.04.2012, 08:02
by ralfso
Not reproducible on my system, either.
Win 7 64bit SP1
FCXE 586
Correction:
I tried it at Extras > settings > drives with full displayed settings tree. Trere's no problem.
Now I tried again with calling the settings window by context menu of the drive bar like shown in video (only the drives settings are displayed).
Now the crash message also was shown.
I think it might have to do with the "single settings window" because with
view > column profiles > details setting you can get also a "single settings window" and if you click on apply you get the error message too.
Confirmed!
Posted: 15.04.2012, 15:48
Confirmed, also with the splitter > settings > Apply.
Posted: 23.04.2012, 21:25
Fixed for the release 587.
Posted: 24.04.2012, 22:46
Looks fixed here, inglorious - please test it.
Closed (will be re-opened if not fixed completely).
Posted: 29.04.2012, 00:09
by inglorious
seems to work now without crashing.
