multi rename
Posted: 28.05.2012, 03:18
by wynford
the counter start at cannot be manually changed, only changes if you use the arrows and if you want to change start at to a high number, you get a ding
Re: multi rename
Posted: 28.05.2012, 07:28
by ralfso
Confirmed, manually typing the digits doesn't work for all the numeral fields in multi rename:
start at, step by, digits.
Re: multi rename
Posted: 28.05.2012, 15:43
Fixed for the release 594.
