Opening selection with F4
Posted: 03.07.2012, 03:01
by Freny
Hello all, and thanks to you for FreeCommander :wink:
I'm actually using FC and watching for use FCXE instead.
I usualy do editing (with F4) for multiple files in selection with FC.
In the 591 release of FCXE, only the latest file selected (%ActivItem%) is opened. :? Can (or have ^^) you make %ActivSel% working too please :?:
Thanks, Freny
Re: Opening selection with F4
Posted: 03.07.2012, 05:02
by Scott_Y
For the current beta release (595): In Settings > File/Folder List, there is an option for what should happen with ENTER when multiple files are selected. The choices are
- Open only focused item
- Show warning before opening items
- Open all selected items directly (not recommended)
I don't know if that is available in 591.
