Context menu FcContextMenu64 stops working, but...
Posted: 06.07.2012, 23:46
by lou53
when I end the FcContextMenu64 process running in the task manager, it begins working again for a while. Evidently the FcContextMenu64 process is supposed to end when the menu closes, but for some reason it continues to run at times causing the context menu to stop working. This is a minor annoyance in an otherwise great app. I use it every day and would be lost without it. Any ideas on how to fix this issue?
Thanks, Lou
Re: Context menu FcContextMenu64 stops working, but...
Posted: 18.08.2012, 21:30
by Scott_Y
A new FcContextMenu64.exe was released July 31, 2012, which solved some delay problems with the context menu.
You might try again with that -- see viewtopic.php?f=7&t=4358#p13060 for a link, or use FC-XE 598.
