591 - Search popup/window issues ...
Posted: 07.07.2012, 20:23
by AEN007
AEN007 wrote:18February2012
Greetings.
Another FCXE search issue I have encountered is that
the the Search Popup (in its own window) intercepts keyboard input made
when FCXE (NOT the Search Popup) is active
IF one (or more) of the found search results is highlighted/selected.
If I highlight a found search result, then do "Focus" (in active tab),
I have to go back to the search results and deselect ALL results;
otherwise the the Search Popup (in its own window) intercepts keyboard input
I make when FCXE (NOT the Search Popup) is active ...
Re: 591 - Search popup/window issues ...
Posted: 12.08.2012, 16:42
by AEN007
12August2012
This week I enabled the Option "&Open dialog on last used position" - (maybe "to" or "at" would be better English/wording than "on" ...).
I have also/already had "A&ctivate profiles tab first" enabled.
After enabling the "&Open dialog" option, the profiles tab is "blank" (for lack of a better word) when it first opens.
I have to Ctrl-Tab away and back to correct the profiles tab display ...
While I am here I would also like to mention that it would be nice if the "Quick Filter" had some memory of previous entries ...
like the Multi rename popup does ... It wuold also be nice if the Multi rename popup had some hotkeys ...
like Replace &with, &Search For, &Rename & etc ...
Posted: 12.08.2012, 18:24
by Scott_Y
... it would be nice if the "Quick Filter" had some memory of previous entries
In 597 (and at least several previous releases) the Quick Filter keeps a history for each tab. The history is a drop-down list, but it does not auto-complete when typing in the filter box.
Posted: 04.09.2012, 10:01
by AEN007
4September2012
AEN007 wrote:I have noticed that clicking the column dividers to autosize does not work properly.
How about adding the option to choose/set search result columns?
Just a thought ...
How about a "single instance" option for the search popup?
