590 - FcContextMenu64 System.OverflowException (Win8 x64)
Posted: 12.07.2012, 21:19
by donovani
I'm running the public preview 590 on Windows 8 64-bit and seeing the following when I right-click on any file/folder. Is this a known issue?
For example, I just right-clicked on "D:\temp\netbook.txt" and I see the following command line:
"C:\Program Files\FreeCommanderXE\FcContextMenu64.exe" "-POSITION=69,809" "-FILE=C:\Users\Donovan\AppData\Local\Temp\FreeCommander3476\F8E7.tmp" -SENDER=4026533862 -AUTOCLOSE=10
Nothing happens but if I attach a debugger I see:
Exception type: System.OverflowException
Message: Value was either too large or too small for an Int32.
mscorlib_ni!System.Number.ParseInt32(System.String, System.Globalization.NumberStyles, System.Globalization.NumberFormatInfo)
FcContextMenu64!FcContextMenu64.FormFcContextMenu64.ExtractSender(System.String)+0x87
FcContextMenu64!FcContextMenu64.FormFcContextMenu64.SetArguments(System.String[])+0x151
FcContextMenu64!FcContextMenu64.SingleInstanceApp.SingleInstanceAppStartup(System.Object, Microsoft.VisualBasic.ApplicationServices.StartupEventArgs)+0x1b0
Microsoft_VisualBasic_ni!Microsoft.VisualBasic.ApplicationServices.WindowsFormsApplicationBase.OnStartup(Microsoft.VisualBasic.ApplicationServices.StartupEventArgs)
Microsoft_VisualBasic_ni!Microsoft.VisualBasic.ApplicationServices.WindowsFormsApplicationBase.DoApplicationModel()
Microsoft_VisualBasic_ni!Microsoft.VisualBasic.ApplicationServices.WindowsFormsApplicationBase.Run(System.String[])
FcContextMenu64!FcContextMenu64.Program.Main(System.String[])
F8E7.tmp contains:
D:\temp
netbook.txt
Thanks! :)
