[ISSUE] It is difficult to drag&drop tab
Posted: 13.07.2012, 12:41
Note: Topic moved to Beta Bug Reports. -Dreamer
Version: FreeCommander XE beta
Op.System: Win7 x64.
1. Open several folder tabs.
2. Drag first tab and drop after the second.
[ISSUE:]
The drop is only possible when mouse cursor is just between tabs. It's odd and worse then in previous version of FC.
User should be able to drop tab more easily.
[ISSUE:]
