Blank icons in SolidWorks
Posted: 21.07.2012, 21:18
I found your program after upgrading my computer from XP 64bit to Windows 7 64bit. I had been using Xplorer2 for the past several years and once I got my new machine and re-installed Xplorer2 the icons in the window for SolidWorks files were blank. I tried a few different programs and the icons resolved fine. I then found FreeCommander and REALLY like the program except the icons are blank here too. All other files show up correctly except SolidWorks files. I'm temporarily using file extensions to distinguish between assembly, part, and drawing files. I've looked around the settings and maybe I'm just overlooking something?
I'm using Version 2009.02b
Here is a screenshot with the SolidWorks files in the left pane and excel files in the right pane. The excel files look fine.
Here is a screenshot of the same directory in Windows Explorer with the icons showing the images correctly.
Any ideas?
Any ideas?
