597 - Search options not saved
Posted: 25.07.2012, 15:21
These 2 options are not saved on Search dialog close, I'd like to disable the second option to search faster, currently I have to disable this option manually for every search.
- Search in subfolders up to level
- Search in archives
I think the second option should be disabled by default.
Re: 597 - Search options not saved
Posted: 25.07.2012, 19:07
It works OK for me. The disabled/enabled option stays disabled/enabled across sessions.
win7x64sp1
Posted: 25.07.2012, 19:20
by Scott_Y
This works correctly for me as well (checkbox status is saved between Search sessions). FC-XE 597, Win7-64.
Posted: 25.07.2012, 19:49
OK, it doesn't work only if "Save history" is disabled.
Workaround is to temporary enable history, change those options, close search window - and then disable history again.
Anyway, I still think it's a bug, "save history" should not affect the other options.
Posted: 25.07.2012, 20:00
Yes, you are right.
Posted: 25.07.2012, 21:56
You mean not "disabled" but "not checked" by default?
Posted: 25.07.2012, 23:40
Hmm.. disabled and not checked means the same, I think.
It should look like this by default:
[x] Search in subfolders up to level [0]
[ ] Search in archives
OK, so it looks it's like that already, don't know why it was enabled for me.
