drag copy/move abiblity out of search files/folders dialog.
Posted: 14.12.2007, 17:49
by honkponk
would be fine in next version.
I'll send this...
Posted: 08.02.2008, 17:33
by kdorff
I am pretty new to FreeCommander and in general like it. After I discovered how to do Key Bindings to Alt-D does an "Edit Address Bar" so it behaves like IE, Firefox, and Windows Explorer. Anyway, back on point.
I did a Search and that worked nicely. I expected to be able to do all the things with the search results that I do in the main window including drag them to my text editor, etc. but it is a very different beast. I would love to have the search results be a more normal Windows Explorer-type view (as the Windows Explorer search results are).
This is the only big lack
Posted: 01.05.2008, 14:37
by angang
Research on freecommander have to be improved >
1. To be able to cut/move the files of the result (really essential)
2. To be able to filter the results and to integrate the “type” column.
Frecommander is the best
Re: drag copy/move abiblity out of search files/folders dial
Posted: 01.02.2011, 02:09
by Landor
I am using version 2009.02a and cannot drag/drop to another program or another FC window. Is there an update on this thread?
Posted: 04.02.2011, 00:45
It's a known issue, please wait for the new - XE version. Until then the only way is to use the Space key to locate the file, or select and copy the files - if you want to use more files. If you want to move the files, you have to copy them, paste where do you want and then delete them in the same search window.
Posted: 04.02.2011, 05:21
by Landor
Thanks for the quick reply. Do you have a target date for the release of the XE version?+
Posted: 05.02.2011, 14:42
Not yet, AFAIK.
