591 - Could/can not drag a file from FrCXE ...
Posted: 27.07.2012, 17:01
by AEN007
27July2012
This week I discovered the (now defunct) XP File Replacer
(which replaces XP protected system files while XP is running ...)
Anyway, the utility uses a DOSbox-like "GUI" onto which the user is to drag the files.
I discovered that I could/can not drag a file from FrCXE.
I don't know if this is a bug or due to some unknown setting ...
Re: 591 - Could/can not drag a file from FrCXE ...
Posted: 27.07.2012, 17:46
by Scott_Y
Three diagnostic questions:
- Can you successfully drag a file from Windows Explorer to XP File Replacer?
- Can you successfully drag a file from FC-XE to other places such as the desktop or other dialogs?
- Is the failure to drag from FC-XE to XP File Replacer specific to the left or right panel, or the same from either panel?
I presume you are running this on Windows XP.
As for settings in FC-XE, I'm not aware of any that would cause this problem.
Posted: 27.07.2012, 18:56
by AEN007
27July2012
Have you tried FrCXE file dragging yourself?
I can drag files from ANYWHERE except from FrCXE - regardless of which panel ...
to ANYWHERE - including FrCXE ...
Posted: 27.07.2012, 22:40
by inglorious
apparently in XE another drag & drop component has been implemented (http://melander.dk/delphi/dragdrop/)
some application will no longer work, search this forum and you'll find more examples.
you may contact the author and report this or stick to FC2009 :roll: .
Posted: 28.07.2012, 00:46
by Scott_Y
AEN007 wrote:Have you tried FrCXE file dragging yourself?
Good question. Yes, I was able to drag files from FC-XE to the Windows desktop, to Windows Explorer, and to several applications which can function as drop targets. (FC-XE 597, Win7-64.)
Posted: 28.07.2012, 04:11
by Scott_Y
AEN007 wrote:I can drag files from ANYWHERE except from FrCXE - regardless of which panel ...
So apparently it is a generalized problem, not limited specifically to XP File Replacer as the target.
Posted: 29.07.2012, 12:10
by AEN007
29July2012
... so I seem to have found the/a (re-)solution and
can now drag files from FrCXE ...
not sure exactly why the replies were so off the mark ...
I can only guess ... maybe I should start a new thread to do that ...
