ahk_l macro for FreeCommander 2009.02b
Posted: 17.08.2012, 22:51
by MilesAhead
I wrote a simple ahk macro for FreeCommander 2009.02b. It sits in the task tray. When an Explorer window is active, the 2 hotkeys are enabled. Left Shift Enter and Right Shift Enter. The hotkeys accomplish the same thing as dragging folders from Explorer to the tab bar to show them in a tab. I just find it convenient to use the keys.
You can get the AHK_L source code from this article:
FreeCommander 2009.02b Macro Utility
To compile or run the script get AHK_L
