action toolbar items w/o icons
Posted: 19.08.2012, 04:11
by username1114
there are these items in the action toolbar that don't have icons,they just leave blank sPace in the tOolbar..it's good thay they're functioning bUt it's much betTer if they have icons..is there a way to aSsiGn icOns for them?even workarounds would be apPreciateD..Thanks!
Re: action toolbar items w/o icons
Posted: 19.08.2012, 05:59
by Scott_Y
Try Tools menu > Customize Toolbar.
Select the command you want in the list on the right, and move it (red button) to the toolbar you select on the left.
Now double-click that command's Details box, then click the ... button for specifying the Icon File path.
Navigate to an icon file, then select the icon you want.
(But see viewtopic.php?f=7&t=4425 for a possible bug.)
Posted: 19.08.2012, 10:11
by username1114
oh..that one did it..fortunately, the bug you mentioned didn't bother me...
it was smooth and easy...thanks!!
