Quick filter in the search dialog - suggestions
Posted: 19.08.2012, 23:17
This feature is very useful, thanks, Marek.
My suggestions:
- It' almost invisible, could you change the default width a bit? Twice at least.
- It would be useful if the shortcut Ctrl+Y would be working also here, the same as in the main window.
Thanks.
Re: Quick filter in the search dialog - suggestions
Posted: 20.08.2012, 12:02
by Scott_Y
I presume you mean Quick Filter in the search results.
How do you get it? I don't see it anywhere in 598.
Posted: 20.08.2012, 12:25
by ralfso
You've first to do a search to have some results. Then the Quickfilter appears at the right bottom of the window.
Posted: 20.08.2012, 12:36
by Scott_Y
Wow, that's nice! Thanks for pointing it out.
I agree that Ctrl+Y would be helpful.
Posted: 20.08.2012, 21:52
The quick filter shortcut (Ctrl+Y), the field width and the color are the same as in main window - implemented for the release 599.
Posted: 13.09.2012, 00:13
I'm not sure about the color - it doesn't fit the Search window colors...
...Perhaps all the colors in the Search results area should be the same as in main program panel, incl. the status bar background/text and "color by attributes / file type".
