[FIXED] 598 Seek icon file for toolbar item hangs FC
Posted: 28.08.2012, 18:04
by Scott_Y
Open Define Action Toolbars.
Open the Details dialog for a toolbar item.
Click on the <...> button for Icon File.
Click on Seek Icon File...
FC hangs. (Win7-64)
Re: 598 Seek icon file for toolbar item hangs FC
Posted: 08.09.2012, 23:04
It works OK for me.
Could you try with the empty ini?
Maybe the dialog is in the background?
Posted: 09.09.2012, 01:51
by Scott_Y
I used a fresh (default) ini file. Yes, the Open dialog to specify an icon file opens behind the previous dialogs. In the order of opening:
1. Define Action Toolbars.
2. Details dialog opens on top of that dialog.
3. Open dialog opens behind the first dialog. (Win7-64)
So FC doesn't actually "crash" as I first reported, but the program is effectively unresponsive because the active dialog is hidden.
Posted: 13.09.2012, 20:58
Could you please check it again in 599, I have made few changes.
Posted: 14.09.2012, 22:22
by Scott_Y
It works correctly now in 599. Thank you!
