Files deleting confirm.
Posted: 08.09.2012, 08:04
And full path with subdirectories in tab title.
Welcome to the FreeCommander forum!
https://freecommander.eu/
A dialog pops up; I think the default is to use the Windows confirmation -- have you perhaps disabled that in Windows? Alternatively, a richer FC dialog is available. See Settings > File/Folder Operations > General tab > Delete; select either "Use Windows" or "Use FreeCommander."Files deleting confirm
This appears in the address bar below the tab (putting it in the tab would make it unreasonably wide). It can also appear in the window title, depending on how you configure Settings > View > Main Window Title.And full path with subdirectories in tab title
