Color of Focused Item bar covered by Sorted Column color
Posted: 11.09.2012, 05:39
by Scott_Y
When Shadow Sorted Column is enabled (Settings > View > File/Folder List > Sorting page), the shadow overrides the color for the Focused Item -- that is, the column shadow is contiguous while the bar of the focused item is broken. The focused item is therefore less prominent than usual and slightly more difficult to spot, particularly if Name is the sort column.
Wish: The Focused Item color will take priority when Column Sort Shadow is enabled. I think this better reflects the functional importance of the focused item over the sort column.
Re: Color of Focused Item bar covered by Sorted Column color
Posted: 15.01.2013, 00:51
by Scott_Y
I'm bumping this up to refresh it in the list.
The problem is that the Sorted Column color overrides the Focused Item color. I consider the latter to be more important for recognizing, selecting, and acting on objects than the former -- particularly when the sort is by name (as it is most often for me). Giving the Focused Item bar priority would result in that color running uninterrupted across all columns. Currently the Sorted Column color runs uninterrupted across all rows -- even though the value and function of that color is secondary to that of the focused item.
Posted: 13.03.2014, 18:15
Confirmed, I agree it should be changed. (FC 654)
Edit: There is a border for focused item, but this border vanish if FC is inactive. Background focused color works for other columns (extension, size..).
