600 - Custom colors for tabs problem
Posted: 23.09.2012, 18:54
by peter77
If i pick custom color for a tab, for example "My documents" and open a folder in this tab, for example, folder "Programs" the tab doesn't change its name to Programs but stays to My documents. I saw this problem only with tabs with custom color, these with default color doesn't have this problem.
Re: 600 - Custom colors for tabs problem
Posted: 24.09.2012, 06:03
by Scott_Y
Confirmed in FC 600, Win7-64.
Note that this behavior is the same as what happens if "Lock Folder Tab" or "Lock Folder Tab - Navigation To Subfolders" is set for the tab -- only with this bug, the tab is not locked.
Posted: 24.09.2012, 08:06
In the "TAB Properies" dialog I see comment to the "Tab name" field: Leave empty for using current folder name.
Posted: 24.09.2012, 10:41
by peter77
Thanks. Leaving the field empty fixed the problem.
Posted: 24.09.2012, 16:57
by Scott_Y
Thanks, Karol. I hadn't noticed that box, and it solves the problem.
