Favorite folders - multibyte characters do not work.
Posted: 26.12.2007, 12:19
by Taesoo Kwon
I am using FreeCommander 2007.10a version with windows XP korean version (which is properly updated.)
I found a bug that "favorite folders" command does not correctly handling multibyte characters.
For instance, in korean version of windows XP, the desktop folder is located in
"c:\documents and settings\username\바탕 화면"
For easy explanation, let me name the above folder using english letters as
"c:\documents and settings\username\AB CD"
Here, A, B, C, and D denote multibyte characters.
Then, after registering the above folder as a favorite, if I click the favorite folder, then an error message appears:
"Directory not found c:\documents and settings\username\AB"
Here is a link to a screen shot.
http : / / mrl.snu.ac.kr/~taesoo/FC_multibyte.JPG
