Dragging & Drop into the Favourites Panel
Posted: 17.11.2012, 03:43
FC XE 0.0.0.604
I discover that if I drag a folder tab into the favourites panel, that there are still some bugs.
First, it seems that the folder of the tab you drag doesn't get inserted - instead, it seems to grab some other folder, I'm not sure where from.
Second, the entire tree gets expanded, and you lose your place (coincidentally, the tree seems to get expanded any time I add a new folder even from the folder's context menu ).
Third, sometimes you get the "NO" symbol when you try to drag a tab into a category folder in the favourites tree.
Also, I think "Add folder to favourites" should appear as an entry in the tab-context-menu.
