FreeCommander vs. Norton Commander
Posted: 11.12.2012, 15:03
by GordonXFreeman
I am an old school NC user. I just happened upon FreeCommander XE. I have been playing with it and like it. One thing I am stuck on....I can't figure out how to setup my panels like I use in NC. Left Panel - Quick View / Right Panel - File Tree.
I like to navigate down through files to see what they contain quickly.
Any ideas on how to do this via FC?
Thanks!
Re: FreeCommander vs. Norton Commander
Posted: 11.12.2012, 18:48
by H.Seldon
Sure! Ctrl+q toggles quickview mode for the inactive panel.
Posted: 11.12.2012, 22:02
by GordonXFreeman
CTRL-Q now splits the windows into two with the viewer below and still a tree above.
I would like to have the full left panel to be a viewer and the full right panel to be the files and directories.
Thanks again!
Posted: 12.12.2012, 05:54
Ctrl+T toggles the tree.
There are more options under "View" menu.
Posted: 22.12.2012, 03:25
by skidplate
GordonXFreeman wrote:CTRL-Q now splits the windows into two with the viewer below and still a tree above.
ATL-T toggles the tree. Drag it left/right to the desired size.
CTRL-Q toggles Quick View. Drag the height of the window to the desired size, all the way if you wish.
