FC and SVN
Posted: 19.12.2012, 16:02
by anpriore
HI all, first post in this forum.
I know the argument is not new, but I need to sort this out and I couldn't so far.
I'm using beta version FC XE 601.
I've just installed SVN version 1.06.16 x64.
I have Windows 7 x64
I don't get the icon overlays even though I've enabled it in Settings.
I cannot get the x32 version of SVN as I know it could solve the problem.
Can you help me?
Re: FC and SVN
Posted: 21.12.2012, 20:58
I use Tortoise Svn 1.7.7 64 bit without problems with FC XE on Win 7 x64.
Check FreeCommander settings for system icons and set the option to "extracted".
Re: FC and SVN
Posted: 02.01.2013, 16:51
by anpriore
Marek wrote:I use Tortoise Svn 1.7.7 64 bit without problems with FC XE on Win 7 x64.
Thanks for your message.
I checked and the settings were correctly set to "Extracted".
I still don't get svn icons.
Any other suggestions?
Re: FC and SVN
Posted: 11.01.2013, 16:28
by anpriore
anpriore wrote:Marek wrote:I use Tortoise Svn 1.7.7 64 bit without problems with FC XE on Win 7 x64.
I'd like to add that I've noticed also that the Windows-like Start button on the toolbar does not work properly in the sense that it does not find the correct path for some of the programs of the actual Start -> Programs menu e.g. Tortoise SVN.
Hence if I click on the Tortoise svn from there it shows me an error message with an inexisting path on it whereas if I use the normal Start -> Programs -> Tortoise SVN the program starts fine.
This goes also for some other programs and I think it is related to the fact that these programs are all 64bit.
May these things be linked together?
