611 - Status bar info incorrect sometimes
Posted: 22.12.2012, 21:10
I'm using custom options for status bar, for most files it's:
[fc_sizeAutoSel]
[fc_sizeSel] Byte(s)
[fc_sizeKBSel]
[fc_sizeMBSel]
[fc_countSel]/[fc_countAll]
Free [fc_discFree]
Sometimes - also in previous versions, the status bar info is frozen, I can't reproduce it, but it happens when selecting and deleting or moving files often. Even manual refresh doesn't work, only FC restart helps.
Re: 611 - Status bar info incorrect sometimes
Posted: 25.05.2013, 16:48
Still not fixed in build 623, here is the video, 768kB size, watch the status bar info while using arrow key to switch files, the info is not changing - then the fresh FC after restart, everything works good.
http://www.swfcabin.com/open/1369491161
Anyway, I still don't know how to reproduce it.
Posted: 29.06.2013, 18:17
I got it, finally!!
To reproduce use my test ini I sent and...
- use any folder with mp3 files
- go to [..] folder
- select all files
- status bar info shows the number of files, e.g. 30/30
- drag any file which is not focused to AIMP, mp3tag or other similar program
- go back to FC, click the title bar
= single file is selected, but the status bar info still shows 30/30
= go to another file, even to another folder, status bar info is still broken
= use refresh, still broken
- the only way can fix it, click (and hold) the empty space and drag a bit
It should be reproducible with any file types, I tested also with images and PhotoFiltre.
Posted: 01.07.2013, 20:45
Fixed for the release 630.
Posted: 01.07.2013, 22:14
Fixed in 630 (not released yet!), thanks, Marek. Topic closed.
