611: "Freecommander has stopped working" on exit
Posted: 08.01.2013, 17:37
by cpk
Each time I exit FreeCommander, Windows tells me that "FreeCommander.exe [..] has stopped working." Although that is technically true, I should not get this message :) .
It doesn't matter what I have done in FreeCommander. Just starting en immediately exiting already gives the error.
From the error dialog:
Problem signature:
Problem Event Name: APPCRASH
Application Name: FreeCommander.exe
Application Version: 0.0.0.611
Application Timestamp: 50d4cd4f
Fault Module Name: nvinit.dll_unloaded
Fault Module Version: 0.0.0.0
Fault Module Timestamp: 503c5228
Exception Code: c0000005
Exception Offset: 74bfce39
OS Version: 6.1.7601.2.1.0.256.48
Locale ID: 1043
Additional Information 1: 0a9e
Additional Information 2: 0a9e372d3b4ad19135b953a78882e789
Additional Information 3: 0a9e
Additional Information 4: 0a9e372d3b4ad19135b953a78882e789
System: Win7 Pro 64 bit, SP1 on a Dell Latitude E6530
Re: 611: "Freecommander has stopped working" on exit
Posted: 08.01.2013, 21:43
One other user have reported similar problem and he has found the solution.
The problem was the dual graphic chip:
The solution: assign FreeCommander to one graphic chip
Posted: 10.01.2013, 11:16
by cpk
Absolutely brilliant. I would never have found that myself. (And could not find the issue on the forum either, maybe I did not search hard enough.)
Thank you and the other user very much. Now I can refrain from Windows Explorer again.
-- Christiaan
