Some files in archives displayed as folders
Posted: 23.01.2013, 21:48
FCXE 612 on win7x64sp1
Archive example:
http://files.first-world.info/supercopi ... rtable.zip
In FCXE the .ini file appears as folder:
In FC2009 it appears correctly:
I use the internal zip feature, but Total7zip and 7zip plugins behave the same.
It may very well not be a bug, but I have no idea what settings I should use...
Re: 612 - Trouble with files in archives
Posted: 25.01.2013, 22:49
Fixed in the release 613.
Posted: 20.11.2013, 21:07
This bug is present again in build 640.
Example archive (portable version of Light Alloy free media player):
http://www.fosshub.com/download/LA_Portable_v4.7.4.zip
Settings window:
Posted: 21.11.2013, 05:37
by Timon
Confirmed in 640.
But it is a little bit different problem, because all previous files that were reported by me as bad in 612 are opened and unpacked without any problems in 640.
So, in that new archive with LA Player there are 2 problems, not 1:
in LA_Portable_v4.7.4.zip\Help\JP\hiddenopts.htm file appears as a folder too!
Posted: 22.11.2013, 21:42
Fixed in 642. Thanks!
Re: Some files in archives displayed as folders
Posted: 09.12.2013, 08:21
A bug appeared in 645, maybe related to the one in this topic.
Now some folders appear as files:
Test archive: the free "yet aAnother Portablizer"
http://rolandtoth.hu/yaP/#download
