613 - How to remove unused toolbar items?
Posted: 26.01.2013, 17:43
I have removed option "toolbar" from Define fav. toolbars dialog for few items, "menu" option is still enabled, because I want these items in fav. tools menu.
If it's impossible to do it using GUI, how to remove it from the FreeCommander.fav.ini file?
Edit: I'm suspecting a bug here...
Re: 613 - How to remove unused toolbar items?
Posted: 26.01.2013, 20:43
- Favorite tools edit... Shift+Ctrl+Y
- Deactivate the toolbars in the list of toolbars (top left in the dialog)
Posted: 26.01.2013, 22:17
Thanks, Marek, I thought this will remove the items also from the menu...
Anyway, problem solved, closed.
