Strange behavior when folder tree display is on
Posted: 26.02.2013, 16:06
If I have the folder tree display on, the active panel will go back to the root directory immediately after I change a folder name. This is quite annoying--why would I want to go to the root every time I change a folder name?
Once I turn off the folder tree display, I no longer have the problem.
