609 Drag and drop from FC to FIJI (Java application) fails
Posted: 27.02.2013, 15:21
by danio368
Not sure whether this is a problem with FC or with FIJI, but drag and drop from windows explorer to FIJI does work, so I decided I would post here.
I can't drag and drop a file to Fiji. When I hover over Fiji with the file to be dropped, it seems recognized since Fiji displays "Drag and Drop", but when I actually drop the file, I get the error message "Drag and Drop failed".
The java code for the Drag and Drop function in Fiji can be found here.
I am using FC XE 609, Windows seven 64bits, FIJI 64bits.
Many thanks in advance for your help.
