618-628 - Search window position isse
Posted: 12.04.2013, 01:28
Minor issue of the search window - the position is not saved properly on close, the part with status bar is moved outside the screen.
It is saved correctly if the window is not near the bottom of the screen, strange.
Re: 618 - Search window position isse
Posted: 16.06.2013, 14:25
New finding...
Even if the search window is placed in the middle of the screen, it's moving slowly down.
To reproduce (also using clean install):
- press Ctrl+F
- press Escape
- repeat previous steps several times
= search window is moving down slowly
FC 628, Win Vista 32 bit.
Re: 618-628 - Search window position isse
Posted: 17.06.2013, 19:16
Fixed for the release 629.
Posted: 29.06.2013, 01:03
Confirmed. Closed.
